It is currently Wed Aug 20, 2025 10:35 pm
 Post subject: 3/32 end mills
PostPosted: Tue Nov 19, 2013 1:21 am
Last Name: Baley
City: Goleta
Zip/Postal Code: 93117
So I am looking at the end mills at LMI and Stewmac and thinking they seem kind of expensive then I look at fleabay and amazon and find out that end mills seem to typically cost 1/5th the amount that LMI and Stewmac are charging.
This seems too good to be true.
What am I missing? Seems like a decent 3/32 end mill can be had for 4 or 5 dollars.
Is there something special about the ones sold by luthier supply places or is it just not their business so their prices reflect their stocking charges?
 Post subject: Re: 3/32 end mills
PostPosted: Tue Nov 19, 2013 6:56 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
Fastenall has Monster mills. Much less expensive and they do a nice job.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Tue Nov 19, 2013 9:24 am
The $5 ones on e-bay work really well. I usually buy the Kyocera ones from DrillMan. He does have .0315" downcuts which actually do make a difference but I do find that so long as they're sharp, the up cuts do a pretty good job. Mine have been lasting forever too.
PostPosted: Tue Nov 19, 2013 12:25 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I bought the Stewmac ones, but not sure if I should have bought something cheaper... I mean a whole set of them runs close to 100 dollars, and no word on how long they last...
Typhoon Guitars
PostPosted: Tue Nov 19, 2013 5:51 pm
There's nothing wrong with the StewMac ones just that they're really expensive. The downcut aspect is nice and it can make a difference, even at that small size but I buy my bits 10 at a time - at their prices that would be pretty cost prohibitive.
PostPosted: Fri Nov 22, 2013 12:29 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
They charge that much because they can. They are about convenience and customer service, which comes at a price.
For the smaller bits (1/16" and less), I use solid carbide dental burs, which I buy in quantity for about 60 cents each. They only have a slight righthand spiral, so 'upcut' is a bit of an overstatement.
IMHO, downcut bits are mostly hype...whatever fuzz on the edge of the cut from using upcut bits can be sanded off in a couple of seconds.
PostPosted: Fri Nov 22, 2013 3:57 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Where can I get dental burrs? I do not know any dentists who are willing to give them away.
Typhoon Guitars
PostPosted: Mon Dec 02, 2013 4:45 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Sorry for bringing this thread up again but I got a problem.
I bought some carbide end mills designed for PCB (they are 2 flute) and those bits are dull, I mean really dull. At router RPM it cuts very slowly and would sometimes burn the wood. I have seen even HSS end mills do better than this, and of course the Stewmac carbide end mill zips through materials (I use them for trimming back overhang sometimes) cleanly. I do not know if this is a case of "you get what you pay for" but maybe there's something to what Stewmac charges. I do not know of the Kyocera end mills are as sharp as Stewmac, I would hope so! Those bits feels really dull, almost as dull as drill bit flutes.
Typhoon Guitars
PostPosted: Mon Dec 02, 2013 5:57 pm
I don't use down cut unless it has a cleared hole , I agree with Mr Arnold on that 100%. The chips can add heat and shorten cutter life. Here are the ones I use. Affordable and lets face it , SHARP , if the cutter is not sharp it is just a piece of shaped metal.
http://www.bqtool.com/square-end-mills.html
you can call them , They actually make a .020 bit for David Nichols and I they are great for detail work.
PostPosted: Tue Dec 03, 2013 12:44 pm
I get mine (downcut) from www.precisebits.com. Nice folks, wide selection & good product. They do have a $50 minimum purchase. However, that's no problem for me, as I like to use a new bit on about every second or third guitar anyway.
michael propsom
www.propsomguitars.com
PostPosted: Wed Dec 04, 2013 9:39 pm
First name: John "jd"
City: Santa Barbara
Hi Dave,
No need to go to Stewmac, Specialty Tool over on Aero Camino has good quality end mills locally.
-jd
PostPosted: Thu Dec 05, 2013 12:03 pm
Last Name: Lee
Country: Wales U.K.
There are hundreds on offer on eBay.
PostPosted: Sat Dec 07, 2013 10:30 pm
Last Name: Baley
City: Goleta
windsurfer wrote:
Hi Dave,
-jd
JD
Completely forgot about specialty. Haven't been there in maybe 15 years.
I definitely need to check them out again. thanks
